A Vista X64 Driver Problem with my TV Tuner
dman918
371
So the one piece of hardware I didn't check about is my tv tuner card (Hauppauge PVR-250). Does anyone know how to get it to work in Vista X64?
Thanks for any help!
Mike
Mar 19, 2003
18,289
If it has drivers for XP x64, you can try installing those and often they'll work under Vista. The only problem is that if the drivers are unsigned, you'll have to use the boot-time options (F8) to disable the signed driver check before every boot...
