A friend of my decided to upgrade his MB to GA-7N400-L
The spec oh his PC:
GA-7N400-L MB
1000 T-bird (C)
256mb pc2100
Maxtor 60gb
Matrox g400
Generic CD
Windows 2k and 98 installed with out a hitch (clean install)
Now the problems began
If you tried to copy a large file say 150+MB
The CPU would go 100% use
And it will take forever and a day to finish the copy
Playing any *.avi ? *.mpg ? files the same thing
And they ?jumped?
This was not the case with the old MB
Basically any even minor load on the system causes a continues 100% CPU load
After hours of tweaking and several clean reinstalls
Both on board IDE controllers were disabled
And PCI ata133 was installed
Now every thing works perfectly
The same IDE cables are in use and the same order master/slave is maintained
The same windows are installed
Same drivers and everything
Other then to assume that both on board IDEs are busted
What could cause this problem?
Tnx
The spec oh his PC:
GA-7N400-L MB
1000 T-bird (C)
256mb pc2100
Maxtor 60gb
Matrox g400
Generic CD
And they ?jumped?
Tnx
