A very peculiar problem.
gamefreakgcb
2,354
Hello. I have a mini-ITX system which was running smoothly so far.
ASROCK Z68M-ITX/HT mini-ITX
Intel i5 2500K a@ stock speed and voltages
2x 4GB DDR3
3x Sandisk 120GB SF-1222 based SSD's in RAID-0
Onboard graphics
This started happening yesterday. The system would do a reboot after exactly 4 minutes and then fail the RAID boot. I have to power cycle to get it to boot. I tried an overnight memtest and it worked all night no errors. I tried to run Prime95 but it didnt stay on that long. No errors are thrown, the computer simply does a reboot. While Prime95 was running, the desktop disappeared, then the Taskbar disappeared, like the systym was shutting down but then thats it. It does not show the Welcome screen with messages like logging off, shutting down, etc. My temps never went above 79C. PSU was upgraded to a 300 Watt Flex-ATX. I am baffled as to what the cause could be. I tried running Acronis to backup but same thing happened. Instead of shutting down though, it started throwing errors that it could no longer read from Sector so-so.
whovous
343
If you turn it on and do nothing at all, how hot does it get before it reboots?
gamefreakgcb
2,354
Hot? Not much stays at 40-45 and then reboots. The bios shows 55C on bootup. I don't know which reading to believe.
gamefreakgcb
2,354
But the comp stayed on all night when I ran the memtest. I'll try putting it to a single SSD and see. Im transitioning to an ATX case with a new mobo soon. a mini-ITX is good but I now see the need of atleast a microATX case.
gamefreakgcb
2,354
Well, I swapped out the SSD's for 2x Corsair 120GB SSD's and the new install is working fine for now.
