How distant? You can do it with a tape, and figuring triangles if they're close enough. To kinda answer your question you may or may not be able to do what you want with a laser or a transit. What are you trying to do?
Your cross pull would be 19' 9-5/8". Unless the ground is very uneven, it shouldn't be too hard. To use a transit, you could setup in the middle of your square, set zero due "north"(assumed), then turn 45° increments, and pull 1/2 the above measurement, but that complicates things, and doesn't make measuring much easier.
Alternately, you could setup on one corner, sight a corner on line, and use 0°, 45°, and 90°, and pulling the appropriate distances to setup the square. That would be a good check after using tapes only. Setup the square using tapes, then setup the transit and wind angles. You don't really have to measure then. Your angles should hit the points you taped to.
Bingo!This seems like a very geometric problem.
http://www.mathopenref.com/constsquare.html
Instead of a ruler and compass I'm thinking strings and stakes.
I came up with 19' 9-9/16. Assuming 14' to the outside of the post. I'm guessing you rounded up because he'll never get them that perfect.Your cross pull would be 19' 9-5/8". Unless the ground is very uneven, it shouldn't be too hard. To use a transit, you could setup in the middle of your square, set zero due "north"(assumed), then turn 45° increments, and pull 1/2 the above measurement, but that complicates things, and doesn't make measuring much easier.
I figured it using decimal feet(cause next to metric it's the sanest measuring system :^P ), then did a trial/error conversion to imperial. I got within 1/8", and figured close enough :^DI came up with 19' 9-9/16. Assuming 14' to the outside of the post. I'm guessing you rounded up because he'll never get them that perfect.
I cheated and drew it out with a cad program and measured it. The software is accurate to six decimals then rounds to the nearest 1/16".I figured it using decimal feet(cause next to metric it's the sanest measuring system :^P ), then did a trial/error conversion to imperial. I got within 1/8", and figured close enough :^D
YesCan you layout the hip roof for me w/1’ overhang? 😀
correctIf I change the square to 14'6" then the diagonal is 20' 6 1/16"?
correct
(14.5^2+14.5^2)sqrt=20.5061
so that gives us 20'6" with some crap left over. The way I handle it without cheating is trial/error math til I get close enough. In this case I'd do (1/16)/12=.00521. Close enough to your .0061 remainder.
There's probably some better way of handling it, but that's what I do. I've spent 30 years using decimal feet, and I'm comfortable doing math with that. If you do a fair amount of projects around the house, you might want to consider an engineers tape with decimal graduations. I got a 25' power tape from homedepot for <$20. Convert your fractions to decimal feet, and enjoy easy math. Of course if you have to talk to anyone else, you'll probably get a blank look :^D
Decimal feet are used by surveyors, and in highway construction. Architectural stuff is in imperial. Carpenters and the home building trades likely have no idea what decimal measure is, and will be confused if you talk to them in those dimensions. For your own use, you can do what you want of course. The power tape I got is DeWalt. Quality seems decent, but I haven't used it long enough. Always got lufkin in the past, but they're getting hard to find locally.
There's no such thing as a perfect measurement. Every measurement is made good enough for the task at hand. I'm not a carpenter, but 2" sounds like too much to me. In any case, it's best to start with better measurements than you need for the project. That leaves room for future error without badly affecting the outcome. If you start out wrong, it probably won't get better unless you get lucky, and leaves uncertainty in the fitment. I wouldn't want my error any worse than 1/4" starting my foundation.
2" out of square will screw up the hip roof. If it was a gable end you could get away with it.
Inside the posts should be 18' 6-1/16". That's assuming 14' outside dimensions.
The diagonal dimension on a 6x6 (5 -1/2 actual) is 7-3/4".
I didn't do any math, I drew it in a cad program and measured it.Awesome thanks! So just curious, on the diagonal since I'm 14' corner to corner are you reducing the 14' figure by 7-3/4" (err 15-1/2") to get that 18' 6-1/16" diagonal measurement for the inside of the 6x6 posts? Or would you use the 5-1/2" measurement of the 6x6?
