A TINY problem in Vista
foolfromhell
277
In the username folder with hte Contacts, Desktop, Documents, Downloads folder, etc., the folders are all green and specialized. For example, the videos folder has a video reel, etc.
Well, today, the Documents folder changed randomly to the yellow generic folder. How do I change it back? I really dont know how.
lxskllr
60,937
11,268
I'm not sure where they keep the green folders to use as a image. You can try right clicking the folder, click properties, then the customize tab. Using the dropdown box pick documents, and see if that resets the image.
foolfromhell
277
Doesnt work.
How do I select an icon as its icon? Like, where is the option to change the icon itself?
foolfromhell
277
nvm. fixed it. I had to go through My Computer to the file instead of clicking on "Sid" (my name) in the start menu.
