- Nov 25, 2012
- 12,086
- 2,774
- 136
So, my sisters Surface Pro 2 had its charging plug damaged, and I decided to splice the connection using the wire from the big OEM charger that she damaged near the brick itself. Upon snipping the original OEM unit, I discover the ground wire is not wrapped in insulation and is wrapped around the three wires present.
The replacement, which the more recently damaged one, has a separate black ground wire. The red wire's gauge is smaller by one size in the RT version as well.
I bought it off Ebay and it was advertised as a genuine charger. The rationale was that if my sister's heavy use and backpack carrying of the surface damaged the original, the replacement will eventually be busted in a similar manner.
http://www.ebay.com/itm/New-Genuine...659579?hash=item28123cb27b:g:1aAAAOSwA3dYJXrR
