A small warning regarding 100W APUs, stock cooler, small cases and highspeed RAM
Insert_Nickname
4,971
1,696
Well, I -finally- got hold of a good 2133MHz kit for my 6800K powered HTPC. After poking around a bit in the BIOS, the 70mm fan on the stock cooler went into overdrive, and checking I was quite shocked to see temps approaching 75C at idle. This without any changes beside the RAM... :eek:
(There is one additional 80mm fan in the case to remove heat from the VRM area, the case is a Silverstone ML03)
I did get into windows all right to run some tests. Idle hovered around 60C inside windows. Likely due to cool'n'quiet. I decided to run some standard stability tests (prime95 etc.), but I did not have the nerve to observe full load temperatures. I shut down the system manually when the core temp reached 106C. I didn't even get a screen-shot of that. All the time the small fan screeched like a banshee, running around 4500RPM. After returning to stock DDR3-1600 9-9-9-27 everything was just fine again, and the system functioned just a it always has. I sure hope nothing was damaged.
The morale of the story is if you plan to run 2133MHz RAM and higher with a 100W APU, the stock cooler is likely borderline inadequate, at least in smaller cases. Or else my 6800K is a fluke.
Has anyone out there experienced something similar...?
AtenRa
14,003
3,362
Which motherboard ??? did you see if there is a newer bios update ??
Erenhardt
3,251
105
101
Have you tried to check if the heatsink is hot in touch? 106'C at core would be unbearably hot on the heatsink. It may be wrong temp readings.
The small fan that screeched, was it a VRM fan or CPU fan?
It was fine with 1600Mhz ram? You mean temps were lower?
dguy6789
8,558
There's something wrong somewhere with the system. Changing RAM could never cause that sort of temperature.
Sohaltang
854
The Ram is the same voltage 1.5 so it should not matter. Even using 1.65 voltage ram should not make that much of a difference.
inf64
3,884
4,692
That was very odd I must say. Ram speed should NOT have such an effect on core temps.
BonzaiDuck
16,792
2,122
I'm just peeking in here . . . Never built an AMD system, even if I considered doing so. But the veterans explain the simple: RAM should not be a difficulty for the CPU.
Even so . . . . 80mm fanz?!! I don' need no stinkeen 80mm fans! Whadda I need stinkeen 80mm fans for?!
Torn Mind
12,078
2,772
Hmm, did you try downclocking the new RAM to 1600 MHz just to see if there was something going on with the sticks themselves?
I guess not, and I don't want you damaging your system, but it could be the RAM...
Insert_Nickname
4,971
1,696
Checked, nearly burned my finger. You could likely boil an egg on it. Also checked with an infra-red thermometer, heatsink temperature was around 80C.
Well, I can rule out an improperly seated heatsink as it has worked just fine until now. Still does with standard 1600MHz, absolute maximum temperature is 65C, swinging between 62C and 64C...
Strange does not even begin to describe it. I had burrowed a 2400MHz kit from a friend a while back, just to verify that the APU could run at 2133MHz without issues. I popped the new kit in my main system (3770non-K) just to make sure its not defective, runs fine at 2133MHz/1.5V with no issues (yet, been stress-testing for two hours now).
I must have gotten the strangest 6800K on the planet...
Erenhardt
3,251
105
101
At least we know that it can be pushed above 100'C. Great for OCing with bad cooler ;)
If you can, try this RAM in other machine. If the problem occur - RMA RAM... ARM...MAR...MRA... whatever, the first time was correct ;)
sequoia464
870
Do you have some different ram that you can install to see what happens?
Edit: never mind this, looks like you did so already. Next time I post I'll read the entire thread first.
Insert_Nickname
4,971
1,696
LOL... :thumbsup:
I talked to a friend, we'll be digging into this issue over the weekend. We'll be pooling some different RAM kits to try out various combinations of speed and timings and he's dusting off an old 140W rated AM2 cooler, so it'll be WITH A BIGGER COOLER... (cue; manic laughter... :twisted:)
Will post results.
Phynaz
10,140
819
How many times do we have to post this.
AMD doesn't post their temperature offsets. You have no reliable way of determining the temperature of an AMD CPU, short of measuring it yourself with a thermometer.
Insert_Nickname
4,971
1,696
And you don't think a fan running full speed and a heatsink temperature of 80C+ indicates -some- kind of cooling problem...?
Remember those ASRock boards that caught fire?
May 11, 2008
22,721
1,486
I have an A10-6700 and recently managed to get ram speed up to 1866MHz from 1600MHz.
This is the specified maximum mammary clock speed for the A10-6700.
I have not noticed any serious change in temperature or fan speed and tried several torture tests here.
I did however replaced the stock cooler with an in my eyes decent cooler.
the Scythe Shuriken Rev. B CPU - 100mm.
I do not know if you have the room for it, but that is a good cooler IMHO.
Also, is there not something wrong with your cooler attachement to the apu ?
22,721
1,486
There is one question on my mind for the experienced overclockers, does the APU downclock itself to lowest possible when it gets to hot to lower the temperature ?
Because if it does, a wrong seated heatsink would seem ok, i guess.
Back in the PII and PIII era, Intel CPU's used to throttle the clock when they got to hot. Is that still the case for modern processors from AMD and Intel ?
Insert_Nickname
4,971
1,696
I wouldn't think so. It has been running fine for the last 6 months or so with quite acceptable temperatures, and the cooler has not been remounted since first installation. Only thing I did change was the thermal compound to some MX-2, because that AMD supplied stuff tends to almost glue the CPU to the heatsink. Making it very difficult to get the cooler off once its cured.
Good point about the Shuriken, unfortunately it will not fit in the case due to a stiffening bracer just above where the heatsink is mounted. It'll also interfere with the RAM modules unfortunately, as they have a heatsink on them, that makes them a little taller then regular DIMMs. The only cooler I have been able to find that -might- fit is the Alpine 64 GT rev 2, but its only rated for 70W.
May 11, 2008
22,721
1,486
Ah , ok.
I do not know if this is an option for you.
I bought memory from GEIL. It is low profile and works good.
I bought it for almost half the price with holiday discount last year.
The EVO leggera series. With a low profile heatsink.
http://www.geil.com.tw/products/list/id/93
I still do not understand why your apu runs that hot.
Phynaz
10,140
819
I honestly didn't see where you posted the fan was running flat out.
Now I'll have to Google those ASRock boards. Fire = bad :)
Edit:
Aha, Trinity boards. Most likely the result of AMD outright lying about their CPU power consumption. Gigabyte got hit by it too. Gigabyte boards intentionally throttled the CPU via proc_hot to keep their power delivery from blowing up. There's a thread here about it.
22,721
1,486
There is one thing i noticed and use as a test.
When i do the prime torture test, my temps(?) are on average 45 degrees celcius. But i do not know if these temperatures are correct.
What is for me more reliable test to see that the temperature is not to hot is the turbo clock option. I trust that cool n quit lowers the core clock when the apu gets too hot.
When looking at cpu-z, my cpu core clock has a minimum of 3699MHz and a maximum of 4299MHz and never goes lower that 3699MHz. That would seem to me a good indicator that the apu is having an easy time.
EDIT :
Correct that, now it drops sometimes to 3399MHz for a second and then jumps up to 3699MHz or higher.
My multiplier is jumping up and down between x34 and x43.
22,721
1,486
I should mention i do the torture tests on both modules (4 cores).
1 core torture test is a constant 4199MHz. :)
coffeejunkee
1,153
Ok, that's weird. You should check cpu frequencies and voltage, I'm suspecting some kind of automatic overclocking feature.
