When CPU usage is low (under 10%), the stock HSF that came w/my Intel P4 3.4 is pretty quiet. But a couple of times it's wound up to about 4K rpm, and 60-65C, when I was running a program that was using 97-99% of CPU for about an hour. (At CPU idle, temp is around 44, and rpm's around 2200.) As far as specs, I know I'm w/in tolerance. But good gawd! The fan in the thing sounds like a small Cessna! Do all these CPU fans sounds like this?
I'm guessing not, from what I've read here. I got an email offer from Newegg, and it lists 3 CPU coolers that fit my LGA-775 CPU:
This Thermaltake
This Artctic Cooling
And this Zalman
The Thermaltake looks interesting, as long as I make sure I've got it well-braced in my tower case, because it has mounts for both intake and exhaust fans, 80 or 90 mm. But I've read here that Zalman is quite good usually.
Since this is my first build, I'm new to the after-market CPU cooling game, so I'd appreciate any advice. And if I'm going to go mucking around w/changing the CPU HSF, I want it to be the last time. At least in this system build, I'm probably not ready to deal w/liquid cooling, but if you think I should, say so.
System specs:
Lian-Li PC-V2000B case
Intel 925XCV
Intel P4 550
Crucial 2 GB DDR2
ATI X600 Pro
PC Power 510 Express PSU
Two 200 GB Maxtor Ultra in RAID 0
One 300 GB Maxtor
NEC ND-3520A DVD burner
If you know this case, the HDs and PSU are isolated in the bottom, and the mobo is fake BTX upside-down in the top. Case has a front 120mm intake fan, a 120mm rear exhaust fan, an extra 80mm fan in the PSU compartment, and a PCI exhaust fan at the very top of the case.
Thanks for your help.
This Thermaltake
And this Zalman
System specs:
Intel 925XCV
Intel P4 550
Crucial 2 GB DDR2
ATI X600 Pro
One 300 GB Maxtor
