OK, so here's my situation.
I have a cable connection, which goes into my LinkSYS EtherFast Cable/DSL Router. I have 2 PCs which i wish to be online right now. A week ago, before i moved my PCs for cleaning and painting a room, both were online. Now when i relocated the PCs, I can only get one PC online at a time.
PC A: Dell with Windows 98 and USB NIC from LinkSYS. [online atm]
PC B: Custom with Win2k and internal FA311 Netgear NIC. [not online]
as soon as i relocated, i could get PC B but not A online. i changed settings in both pcs, switched rj45s around and for 5 days straight now i have A but not B online.
no matter what i do, what i change, i can't get PC B online. I have been able to get only 1 pc on at a time, and the scary thing is that my brother said that he "thinks he dropped the router and it made a bang."
multiple times i have taken the router out of the equation and tried to put PC B's rj45 directly into the cable modem. no luck. i reinstalled win2k (things were starting to act up anyway) and no luck.
PC b, which i had online a few days ago will NOT go on, no matter what. A will go online through the router or not.
now, when i run "ipconfig" on the win2k (PC B), i get the following:
IP: 192.168.1.100
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.1.1
when i run "winipcfg" on the 98 (PC A), i get:
IP: 24.187.---.---
Subnet Mask: 255.255.240.0
Default Gateway: 24.187.---.---
I know this is pretty lengthy 😛, but if you can help, please drop any suggestions 🙂 thanks.
IP: 192.168.1.100
IP: 24.187.---.---
