Hi all, I have a SMC7004VBR router installed for my home network. As a result I am behind firewall. At times, when I tried to access a particular FTP with an odd port such as 444, no matter I enable pasv mode or not in my cuteFTP client, I will not be able to access the directory listing!
Is there way to bypass this problem? Is there a setting I must change in the web panel? Can someone with knowledge with my router provide me with some solution?
Thank you!
Thank you!
