A Satellite Wireless Network
DannJonnes
I?ve been given the task to create a satellite wireless network for a lake side resort. The goal of this is to allow the patrons to access the internet through this wireless network in the form of a cyber café.
HughesNet is a satellite provider I am considering but I am always open to new ideas and suggestions.
The problem I am foreseeing is the distance the wireless signal would be able to be relayed. There are several cabins that are within 50 feet of the main lodge and several further away. Basically, we want to create the largest hotspot that we can to allow the maximum amount of patrons to connect to the internet.
What kind of router/repeater combos should I be looking into?
Does adding several repeaters ruin the signal?
What kind of wireless distance could I expect to get?
Thanks for the help and any suggestions.
James Bond
6,023
If you put a decent router in the Cyber Cafe it would be possible to have a couple access points which could bridge the signal towards the cabins. 50 Feet isn't too bad.
I'm sure someone will be able to link you with a decent router/AP
DannJonnes
Thanks, good to know. Some of the cabins and RV park are 100 yards away and im thinking that may be a strech. Hopefully someone has a like to a good router, thanks again.
kehi
3,357
what kind of internet speeds are we talking about. The link you posted showed some fairly low speeds. How many clients are going to be using this at once?
sieistganzfett
588
What kind of router/repeater combos should I be looking into? connect a heavy duty long range wireless ap to a router, to the modem from your provider..
Does adding several repeaters ruin the signal? NO, but the speed is cut in half on the linksys one i used, i perfer not using it unless i have to, but to the computers that access, it all looks like one huge network's ssid.
What kind of wireless distance could I expect to get? depends on a lot of things but there is hardware where a single ap can give you several kilometers in range! for your situation i would opt for a single semi long range wireless, it of course would need to be mounted on your roof, but since you may go for satellite, you will have stuff on your roof anyways. linksys, which even has a trade up program with cisco, who has a lot of good stuff, call a rep there and say what you need, its out there but will cost a bit. around 1k for the wireless hardware from what i remember for up to a kilometer, 1k for the satellite internet hardware.. none of this factors in labor if others set it up...also, i am currently dealing with issues a client of our's is having with hughes net... the internet is shared bandwith, so when a lot of people are on, your internet will run very slow, hughesnet guarentees nothing so if you never can get on, oh well.. it may not work at all since it may go from fast connection to slow/none, which is what our client that uses them experiences...also, talking to their tech support which takes sometimes 2hrs to reach after the hold is no help. they will only officially help you if its one computer directly to the modem, but it really depends on the person who answers your call. there are a few others out there, direcway was bought out by hughesnet.. all give about 300kup/1M down for about 100 a month, where the hardware costs about $1000.
Goosemaster
48,775
AYe. looks like 1Mbps /200k ! is the highest plan available. That is pretty bad.
You have no choice but to use traffic shapping in this case. M0n0wall is a great choice for this.
sieistganzfett
588
they all have more expensive options that give around 600k up/ 2m down for about 200 a month and that one gives static ip included in the price from hughes.net. here are a few others i remembered when i did the research for my company.
http://www.tachyon.net/index.html <-i think you should check this one out but you must do research on them compare what gives you the best and what they will guarentee, if anything. only go with satellite if you can not get dsl or cable, or if them running a line would cost more than satillite.
http://www.agristar.com/systems_plans.shtml
http://www.starband.com/smalloffice/index.asp
DannJonnes
At most, there would only be 5 users on at the same time. This is a small resort that offers more of an "escape" from technology but we want the option to be avaliable. And if people were using this connection, it would be mostly just for email, chat, ect. Nothing that would demand a high dl/ul rate.
wlee
585
Since you're stuck with a satellite ISP, I would also suggest a caching proxy like IPCOP to help speed up browsing and control bandwidth. As another user suggested, mOnOwall might also work *IF* it supports caching.
