It will work just fine for now,
but as soon as the new clients are mandatory it
will not work unless you change the address SetiQ connects to, which btw I don't know.
The new client uses a different address for the server than the old ones did. SetiQ uses the old address as well, so once they cut off the old address setiQ won't be able to find the server.
SetiGate will work but you have to manually enter the new server address, that is unless they've updated the software to already use the new address. SetiDriver will also work just fine with the new client without you having to do anything.
Edit: I guess I should have included that I'm currently running 3 machines with v3.03 connecting to SetiQ without doing anything to SetiQ. I think what Ken said is correct. All you have to do in SetiGate is change the server address it connects to & SetiQ will let you do the same thing so I would assume it will work.
