thecoffeeguy
1. What will computer be used for?
Primarily gaming and web surfing (son plays flash based games).
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
Budget is $450
3. What country YOU will be buying YOUR parts from.
USA
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
Not really any fan-boy, but this rig will be intel.
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
GTX260
Seasonic 620w PSU
7. IF YOU plan on overclocking or run the system at default speeds.
No overclocking will be done.
8. What resolution will you be using?
1900x1280
9. WHEN do you plan to build it?
Immediately.
For the past year, my current rig has been very problematic and unstable. I will spare the details for now, but i'll just say that I am frustrated and ready to move on and build a new rig.
What im looking for is a nice, stable, fast rig and am keying in on a i52500 chip. I really just need help picking a mobo and memory (my last setup, I had some issues with the mobo, memory and timings, that never seemed to get stable after a lot of work put into it.) That being said, I really dont want to mess around with timing adjustings, overclocking etc. Just want a fast, stable and reliable rig.
Since I have the chip picked out, anyone recommend a mobo and memory to go with?
Going to be picking up a new vid card (haven't decided) and outside of that, just 2 hard drives, DVD drive and thats it. I have a seasonic PS, which should be fine.
I appreciate the help. Sorry if this sounds dramatic. Im just frustrated and want to move on.
Much obliged.
TCG
