Been looking for a boot load program that actually allows you to boot multiple OSes without having all of the boot sector, boot files etc exactly how they would be normally to boot anyway.
For example I have tried lots of programs that were useless to me because all they do is execute the boot files that are already there (but they are messed up so it is just the same as not having it at all.) GAG, Smart Boot Manager, a few others... All they do is go to the boot.ini menu anyway, defeating the purpose and not giving me any way to boot 98.
I could get one, or the other to work, at different times manually, but I can't get both. XP is fairly easy to get to boot again by running the cd, recovery console and using bootcfg /scan and bootcfg /rebuild. I tried using various tools to generate a bootsec.dos file, but it fails and won't run, making it impossible for me to get 98 to boot as well as XP.
While it is possible that if I wiped out everything and installed 98 then XP from scratch it may work, I really would like to avoid doing that for fairly obvious reasons. Suppose I don't get why no one has ever written an actual program that will scan for operating systems, let you tell it what each is exactly and take care of tweaking/adding/removing whatever is necessary to actually get each to boot correctly.
Acronis OS Selector is the only piece of software I've found that claims to actually be able to do this. Which I supposedly own, however, I can't get the POS to work either because it stops me at adding a license key when I use the bootable media and won't accept any key I have for disk director, not 10, 11, or 12... Which makes no sense since I had 12 installed when I created that iso to burn the rescue media that has the option to load OS Selector and Disk Director 12 is the only Disk Director that was ever installed on the machine I used to create/burn the rescue media that has OS Selector available to use when it boots up on the cd.
So, I'm looking for something else, that can basically do the same thing, look at at least 2 OSes, fix the mbr, shuffle whatever files necessary and just make the darn thing work. I've been monkeying with this manual sh*t all day and have gotten nowhere.
Anyone know of anything?
