Maybe im just paranoid, but feel like my computer has become louder since the time I built it a little less than a year ago.
Anyways, I have a X-Dreamer case, clear side panel with a led fan, and a similar no led fan on top. Antec 350 smartpower psu. p4 2.4ghz (the one with 533 fsb). Currently overclocked to around 2.88. Abit is7. I had a problem with the abit is7 chipset or motherboard fan. It died, so I replaced it with thermaltake tiger 1 combo.
With some investigation, its not the case fans, or the chipset fan contributing to the noise that much. the power supply, radeon 9600 pro fan, or the cpu fan is making the most. Nothing I can do about the psu/radeon noise. (well, without replacing them and spending a lot).
So, the question is how bad could the stock fan be compared to other solutions. I am probably willing to spend about 30 if I can get a significant reduction in noise compared to the stock fan. Any ideas??
The noise is not like unbearable or anything, but would like to reduce it as much as possible since I will be running it 24/7 as a server.
Also, please let me know of any expensive solutions that you think may blow me away with its quietness. I may consider it buying it later if worth it.
thanks in advance
thanks in advance
