A quick question please help!!
MikeR2323
I have a labtop that i want to load win xp and win 98se onto...i load win xp fine, i go to load win98se on it and it gets to the pnp drivers and stops!!! Any ideas on what it could be!!1 Please hurry this is a business labtop!!! Thanks...
Not sure why you want to dual boot it. I thought that you should either put 2 partitions on the HD before installing and then just install one to each drive. Otherwise, I also thought that you should install 98 first.
Here's a linky that might help. It's 95 and NT but those are the platforms you are working with, sorta.
