A question on terminating autostarting programs and antivirus
Battousai001
If I want to terminate auto-starting programs like antivirus do I have to disable also the entries on the "services" tab (service.msc) of the msconfig or just disabling the entries on the "startup" tab enough? cause when I try to disable auto-starting program on the startup the entries on the services tab is still checked (but the programs and antivirus seized to auto-start).
I would like to be sure if the auto-starting programs are 100% terminated and that unchecking entries on the "services" will do it?. And will the programs (specially antivirus) still work fine if I disable the services entries?
