- Mar 6, 2004
- 532
- 0
- 0
Hey All
Ok, so recently I have been turning off my 'Screen-Savor' function and just doing the 'Turn off Monitor' after x-amount of minutes.
So that got me wondering about using Windows built in Power scheme, you know the one that can be found under Display-Properties/Screen saver/Power-Tab
Its set up like this:
Turn Off Monitor ----- [after XXX amount of minutes]
Turn Off HDDs ----- [after XXX amount of minutes]
System Standby ---- [after XXX amount of minutes]
The reason that I was wondering about this is because since its better to NOT turn of your system everyday I was thinking about actually trying this function out.
So if I was to 'turn off the HDDs' does sthat mean that Windows actually shuts down completely?
Like would I have to worry about my Firewall not being usable??? and would I be susceptible to an attack?
Also, if I activated the 'System Standby' does that turn everything off and if so do I just move the mouse or hit the keyboard to come out of 'System Standby' mode??
Thanks,
Regards,
CA
Thanks,
Regards,
CA
