- Mar 17, 2000
- 523
- 0
- 0
I have used pcAnywhere and altoght it is nice it doesn't allow to "remotely use" an appliction on one PC without rendering the "host" PC useless (both PC's are 'doing' the same thing - one is running the app. and the second is showing the screen-output of the first - you can work on the target but the host is uesless becose you can't use it for anything else...
(you can run RC5 but you can't do a 'productive work', not even surf the net becose the target PC will show the host screen...)
is there a program that can use the "cpu-power" of a host PC to run some app. (say Word) and in the same time will allow the host PC to do other things (surf the net) - a program that will leave the host PC "independet" from the target PC and won't sync. between them like pcAnywhere (9.2) does.
I haven't used VNC - can it do what I need?...
this matter is urgent for me... so thanks in advance
