A question about 64-bit pci slots. plz help
chasem
Banned
Dec 17, 2001
705
Will a 64 bit pci card fit and operate (at a lower speed) in a 32bit pci slot? plz help!
mechBgon
Oct 31, 1999
30,699
AFAIK, 64-bit PCI cards are designed to be backwards-compatible to 32-bit PCI slots. The extra contacts just hang out off the end of the PCI slot. Anyone know if this is an ironclad rule?
Smilin
7,357
I didn't know that I guess.
I know the 66Mhz are backwards compatible to 33Mhz bit I didn't know 64bit went to 32.
sharkeeper
10,886
If the manufacturer allows for reverse compatibility, then yes it will work. I've used 64/66 HBA's in 32/33 slots before albeit much lower performance.
Cheers!
Priit
1,337
AFAIK 33Mhz 64-bit cards should work in usual 32-bit slot (at least those I have seen/read have been working). You can also put 32-bit PCI cards in 33Mhz 64-bit PCI slots. 66Mhz 64-bit PCI slots/cards on the other hand aren't compatible with 32-bit PCI slots (they don't physically fit ).
