A problem .
FluxxoR
My pc wasnt working , I think because of memory , I by a mistake turned the memory thingy from 200 mhz to 233 and now the doesnt even turn on , it just gives a black screen ... what can I do about it ?
So it wasn't working before, and it's not working now. Memory thingy. Jumper? BIOS?
How about some more information.
Before , it just froze after some time , I scandisked , used O&O diskfragmenter , spyware thingys and virus scan .
My pc froze in games , epecially when there was some loading ( so I fought its ram problem ) .
Well by an accident I set ram mhz in bios ( or what it was called , ddr or mhz something ) from 200 to 233 , now when I turn on my pc , nothing happens , screen stays black , nothing , no sounds like when loading windows etc after time so no monitor problem ... no vga problem Im sure .. just that now I cant even get into bios and put default on ....
Just want to know what to do to get anything on my monitor .
Reset the CMOS. There should be a jumper on the motherboard to do this. The procedure can vary depending on the board. If you have the manual for the motherboard, the procedure will be spelled out exactly.
Otherwise, unplug the computer. Move the jumper to the reset position for a few seconds and then move it back. If you still cannot get into the BIOS, repeat the procedure removing the battery for 10 minutes.
also, try removing and reinserting your cmos battery. its just a little watch battery. that resets your entire bios and motherboard.
