who woulda thought?
anyways, long story short i have a HP orinoco card for my laptop, which is detected perfectly on windows xp home. I have a Linksys BEFW11S4 router. The computer i am on is a real connection to the router. This connection has never failed me. The problem is, i can use the laptop wirelessly for a bout 40 minutes, then the connection to the laptop is shot, and i have to reset the router for things to work. ALl the time my normal connection is fine. The router is the DHCP server, i set it to hold 10 cleints, but there are only 3, so i dont think that is a problem. WEP is turned off, you have to be in my house to have a connection, unfortunalty the range doesnt extend outside. BTW, the DHCP server refreshes every 3 hours.
I would really appreciate some help from all you gurus (i can hear it now- "not another newbie with a wireless lan!")
