A problem with no solution ?
RustyNale
2,220
Make sure you comp isn't set to reboot automatically if any errors occur. Right click my comp,----advanced tab,----startup and recovery..settings tab--and unclick automatically restart. Now if you have any errors it will write it to a log file that you can then read to see what the real problem is..That is to say if it's a software issue.
If it's a hardware issue, I'd start by making sure your hsf is seated properly, the memory is ok, and that your psu is stable for starters.
