A Place for Buying Wifi Coax Cable Wire for antenna?
promposive
I need a place to buy coax cable with the following connectors and sizes, the sizes are variable, but anyone know of a good place to buy premade cables? Or cheap supplies to crimp my own?
1x RP-TNC -> N-Male 3 feet
1x N-Male -> N-Male 1 feet
1x N-Male -> N-Male 3 feet
I would like cable of greater quality than LMR-200
Nope, that's about right. You aren't going to get quality cable (time microwave LMR-400 for instance) cheap. 67 bucks for 40' LMR400 with TWO connectors is very reasonable.
....and don't even think of doing your own.
There's already a lot of loss ... even with commercial-grade cabling .... you stand a snowball's chance to do it well enough to make it worth while.
Check Fry's / Outlook.com ... I know their B&M store has pigtails & cables ... don't know the prices though.
Good Luck
Scott
