If anyone has any ideas why something like the below happens, any advice is appreachiated.
I just got an enermax 470W noisetaker. it worked fine for a couple of days and then suddenly this happened...
I go to turn my comp on one night and it turned on for a split second and turned off. I was thinking surely it didn't burn out. After some fiddling, I've located the problem. My Aerogate II. (P.S. The Aerogate II is a rheobus by Coolermaster and it's essential as I use it to control all the fans in my case and reduce the noise)
I tested it with nothing plugged in except the motherboard and the Aerogate II. Pressed the power button and it just will not boot up. I thought I had a buggy aerogate so I went to work and picked up a spare Aerogate II we had lying around and tested that brand new one. Exact same thing happened. Split second boot up and a safety shut down.
The computer boots up just fine with ANYTHING else plugged in, I even tried extra hard disks and fans just to see if there is a lack of power or some fault. There is absolutly nothing wrong with the Aerogates I tried, they both work in my spare system. The Enermax simply refuses to boot with that part plugged in.
Ok, now what the hell is going on here? It worked for a few days no problems then suddenly it decides not to boot now when this rheobus is plugged in...
