a newbie needs help with subnetting.
puribong
31
hi...
I started to taking a network course and my teacher game me a homework. I paid attention in class as much as possible but I still don't know how to do with the homework. I hoped that maybe a somebody can help me with my homework.
oh well here is one of the questions from homework. I think I will able to do other questions in same kind if I can figure this question out.
Requried Number of Physical Segment: 100
Maximum Number of Hosts/Physical Segment: 88000
Network Address: 39.0.0.0
Proposed Custom Subnet Mask: ? I need to figure this out.
Number of subnets supported: ? this one too.
Maximum Number of Host ID per Subnet ? this one too.
as you can see above, I am given first 3 field, and I need to find next 3 field. I know that 39 is Class A and default gateway is 255.0.0.0 but I am stuck there. I don't know what to do from there.. Can somebody who is genius in Networking maybe help me?
Thanks a lot in advance..
cleverhandle
3,566
Well, for an n bit netmask, you get 2^n - 2 usable addresses. Trying some values for n out on the calculator says that n=16 only gets you 65534, so you need n=17 for 131070 hosts. So grab your textbook and work out what a 17-bit netmask looks like in xxx.xxx.xxx.xxx notation. And once you figure that out, it shouldn't be too hard to figure the maximum number of subnets either.
randal
1,890
REMEMBER: Host bits start from the right, network from the left
You know you're working with a class A network. That means you're losing your first octet to network:
nnnnnnnn.????????.????????.????????
You know you need 88,000 hosts. Well, the only thing near that is, as said before, is 2^17, 131070. That means you need 17 host bits:
nnnnnnnn.???????h.hhhhhhhh.hhhhhhhh
What's with the ?s. Well, we've got network and hosts, so we're missing subnets ...
nnnnnnnn.sssssssh.hhhhhhhh.hhhhhhhh
If you count those Ss and Hs, you'll get 7 and 10. 2^7 = 128 Subnets, each with 2^17 = 131070 Hosts
1 - 39.0.0.0 - 39.1.255.255
2 - 39.2.0.0 - 39.3.255.255
3 - 39.4.0.0 - 39.5.255.255
4 - 39.6.0.0 - 39.7.255.255
127 - 39.252.0.0 - 39.253.255.255
128 - 39.254.0.0 - 39.255.255.255
Usually, once you find the correct number of bits to mask off for hosts or subnets, it all falls into place.
However, sometimes they'll tell you something like ... you have a class B network (say 160.32.x.x), and you need 48 subnets. What is the subnet mask and # of hosts per subnet?
The class b tells you that you're losing your first two octets to network:
nnnnnnnn.nnnnnnnn.xxxxxxxx.xxxxxxxx.
You know that you need 48 subnets ... well, the closest thing is 64. 2^n = 64. n=6. Hence, you get 6 subnet bits, and the rest become host bits.
nnnnnnnn.nnnnnnnn.sssssshh.hhhhhhhh
11111111.11111111.11111100.00000000
255...........255...........252...........0
If you count up the Hs, you'll see there are 10. 2^10 = 1024 hosts per subnet.
This applies to Class C networks, where most people spend their lives because they don't get to work with Class As ;-) ... say you have a class C of 209.12.100.x. You need to slice that up into a bunch of subnets, each with 4 hosts (say it's for DSL or something). The work here is almost done for you already -- you are class c, so you lose three octets to network. You need 4 hosts per subnet. 2^n = 4. n=2. So that gives you 2 host bits. The rest becomes your subnet.
nnnnnnnn.nnnnnnnn.nnnnnnnn.sssssshh
255.255.255.252
6 Ss, 2 Hs ... 2^6 = 64 subnets ... 2^2 = 4 hosts per subnet.
All it boils down to is determining the number of subnet or host bits (whichever it's asking for), and then sticking them in the right place -- network bits on the very beginning, then subnet bits, then host bits.
Yes, I know this is not the most scientifically/mathematically exacting way to do things, but it helps me get past the truckload of confusing ones and zeros ... knowing n is network, s is subnet and h is host always makes it a lot easier for me to follow.
randal
randal
1,890
Surprisingly, I started doing it that way not because I learned it like that (I was taught the 1s and 0s method), but because I was using Wild Packets IP Subnet Calculator, and it has a thing on there called the "Subnet Bit Map". I glanced at it and it blew me away at how easy it made things -- instead of numerous ones and zeros, you get to work with 3 subsets of smaller letters.
Although I can still do it by ones and zero (which is just the nitty gritty of the letter method), I almost *never* do. Breaking down the subnet into it's three parts just makes things easier.
Oh, and just an FYI for you up-and-coming network guys, most people don't work with anything bigger than a couple class C networks ... at least until you attain Guru status *cough*spidey*cough* and become the network admin for a huge megacorp that has millions of IPs. I don't think I've had to do any supernetting for any job, and where I work now we have over 4,000 IP addresses.
Cheers,
randal
