SkylineRider
Hi, I'll make it brief & quick.
I tried to overclock my X2 4400+ Toledo to 260Mhz x10.5 and it's running smooth. However, I figured out that my (2gig) Kingston 400 DDR (pc3200) is detected to be running at 133Mhz when I set it to "Auto" configuration. I tried to force it to 200Mhz (I assume DDR will double that => 400 like manufacture rating) but then realize that the CL would be automatically set to 3.0 instead of 2. Whenever I tried to force the Cas. Latency back to 2.0 the computer would crash!! So I have to live with the setting of 2.5 ....... Can anyone help me out with this problem? What would be the appropriate settings (FSB, multiplier, ect.) to obtain 2.7Gig CPU, 200Mhz (or a lil higher) memory frequency with CL of 2.0 ?? I know there's an equation for this, but I can't locate it anywhere in this forum, yet. I really need your help, this is my first time building & overclocking a computer.
Thanks
F.Y.I
Mobo: ASUS A8R32-MVP Deluxe Socket 939
CPU: AMD Athlon 64 X2 4400+ Toledo 2.2GHz 2 x 1MB L2 Cache
Memory:
Kingston HyperX 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Dual Channel
Capacity 2GB (2 x 1GB)
Speed DDR 400 (PC 3200)
Cas Latency 2
Timing 2-3-2-6
Voltage 2.6V
ECC No
Buffered/Registered Unbuffered
Heat Spreader Yes
Thanks
F.Y.I
Memory:
Cas Latency 2
Timing 2-3-2-6
Voltage 2.6V
ECC No
Heat Spreader Yes
