petrusbroder
On one of my computers the browsers (IE, Firefox, Chrome) and BOINC (software for distributed computing, has been working well for me in all the different versions for a decade) can not communicate with the internet. I have no trouble of reaching the router using any of the browsers, no problems with ping-ing, Windows Network fault solver says that I have internet communication, I can see all the other computers on my network, all the other computers see the "problem computer". The only thing I can not do is browsing the net and using BOINC.
None of the other 9 computers on my intranet have that problem.
This problem occurred after I did a weekly clean-up using the current version of CClean and a registry clean using RegClean Pro - both of which i have used "for ages". I also deleted quite a few programs (image management, office, mediaplayers, etc I have not used for a long time). After deleteing those programs I ran the registry cleaning once more, shut down the computer, and then the problem occurred when the computer restarted.
I suspect that the registry clean-up messed up something.
A rollback of the registry changes did not restore ability to browse the net.
The fun part is, that Windows own diagnostics does not see any problem with the internet connection.
I am reluctant to re-install windows or to upgrade to Win 8.1 because that probably means to re-install all my productivity software (office programs, statistics software, video-editing software, image processing software, mail, etc., etc, etc. I do not have a backup of the whole system - that would take some 280 GB (system+programs) + 500GB data. I have a complete and current back-up of all the data on an other computer, so the documents, images, videos, music, etc. are safe and sound, I have checked that. What can I do before I reinstall the system?
- Windows 7 Home, all updates current.
- I have scanned the computer for viruses using Windows defender, Malwarebytes, search-and-destroy - no infektion seen.
- I have checked the router and switches - no problems.
- I have reset the router to factory settings, does not solve the problem.
- Windows 7 Firewall off - or on - does not change behavior.
- AVP- on or off - does not change behavior.
- Reinstalling browsers and BOINC - latest version - does not change the behavior.
- Resetting the network properties (control panel) - did no good.
- Switching to WiFi (installing a USB-modem) - did not restore browsing or BOINC-function
- Installing a new network interface card did not restore browsing or BOINC-function
