a more effective way of measuring temps on a newly built WC'd machine...
abhong
143
as the topic says, anyone can suggest/link a better way of measuring temps on a newly WC'd machine?
aigomorla
21,087
3,596
it would help if you listed out the methods you already know.
But if you mean software wise, i use coretemp.
abhong
143
ha ha ha...
seems to be getting good learning experience from a person who's board name is "dont know" no wonder it sounded familiar...
well, i was told the temp reading at bios really tells nothing because your CPU is not really doing anything and so i want to get some better way of measuring temps.
Coretemp is what i've heard in the past... i just couldn't remember it at the moment.
thanks!
Korean-American i see... well thanks for the info.
