- Year
1995
- Make
Eagle (Mitsubishi)
- Model
Summit (Mirage)
- Engine (if there are different engines available)
1.8L SOHC
- Trim Level
ESi
- Modifications (if any)
none. Serviced at 100K with new serpentine belt and distributor kit w/ plugs and wires.
- Mileage
102K and change.
After the car warms up and you drive it for a while - when you press the clutch in the car idles extremely low, below the little tick between the 0 and the 1 on the tach that shows you where it should be when idling. It doesn't take much - sometimes just turning the wheel with the clutch in making a corner or just sitting at a light right when you roll up to it will kill this thing. It's happening frequently now, probably 3 or 4 times a day in an hour or two commute. The car fires right back up though as soon as you turn the key.
I have most of the weekend to pop the hood and troubleshoot so give me your best suggestions!
TIA
			1995
- Make
Eagle (Mitsubishi)
- Model
Summit (Mirage)
1.8L SOHC
- Trim Level
ESi
- Mileage
102K and change.
TIA
 Facebook
Facebook Twitter
Twitter
