A little problem with HL/CS
Sunner
I have a problem with HL/CS on one of my comps.
Thing is, everything's moving at warp speed, like 2.5-3x the speed its supposed to be.
Its definately something with HL itself, since it happens in both HL, CS, and some other wierd mod that a friend of mone tried on the comp.
Everything from running, to firing happens too fast, and if a server is hosted on this comp, any bots on it are fast as well.
Now this does make a great cheat in multiplayer obviously, but Im not the cheating type, so I'd rather get rid of it.
The comp is a K6-3 450 MHz, 128 MG SDRAM, Permedia 2-8 MB & V2-12 MB, on an Asus TX-97 XE.
OS is Windows 2000 Pro Sp1, using 3dfx beta drivers for the V2.
HL and Counter Strike are both patched to the latest versions, though it was like this in a previous version of HL as well(cant remember the number but it was post 1010).
Sounds like someone tried the speed cheat on it. I would try and find where the speed cheat is on the net and find out what the Windows setting is that does that. If you can't find it, you'll likely need to re-install Windows to fix it. Maybe you should shake down the peeps who were using that sys, and if they played online, smack them for me!
BTW, I dunno where to find the info and even if I did I wouldn't give a link to it. Cheating is lame. 🙁
