Not too sure where to post this, but I figure since this group might be good with terminating CAT5, someone might know about RJ6.
I am doing some cable TV runs using some generic RJ6 cable. I am curious to find out whether I should be removing the foil from the wire.
First, I strip off the rubber, leaving the wire weave, foil, insulation, and copper core, as seen below.
http://carrington2.0catch.com/DSCN1320.JPG
Then I pull back the wire mesh stuff and cut it as close as I can to my other crimp point. Then I remove another section of everything, except, of course, the copper wire, as seen below.
http://carrington2.0catch.com/DSCN1321.JPG
Then I put on the connector and cut the copper wire so that's its a few mm past the end of the connector.
My question is this: do I need to pull back the foil, or am I ok leaving it? Will it make any real difference? FYI, I'm using the twist on F-connectors.
Thanks all!
Aaron
PS, if you want to see the pics, you might need to cut and paste the URL's. Sometimes this free site is a little funny about hotlinking from other sites and will not allow you to view the pics.
Thanks all!
Aaron
