A little math for ATOT!
TecHNooB
7,458
Sum from k = 0 to k = infinity of k*(0.5)^(k+1)
I haven't seen my calc book in quite a few semesters :p
TecHNooB
7,458
Originally posted by: theplaidfad
Do your homework on your own.
(I don't know the answer)
I'm stuck on this problem :p If only I was as smart as you :(
blinky8225
564
It's 1. I'll edit it with a solution in a bit.
So the series is:
Let the lim(n) approach infinity
0 + (.5)^2 + 2 (.5)^3 + ... + n(.5)^(n+1) = (0.5)^2 * [1 + 2 (.5) + ... + n(.5)^(n-1)]
Let.....S = [1 + 2 (.5) + 3 (.5)^2 ... + n(.5)^(n-1)]
then 0.5 * S = [1 (.5) + 2 (.5)^2+..+(n-1)(0.5)^(n-1) + n(.5)^(n)]
See how they line up beautifully?
So S - 0.5*S = 0.5*S = 1 + (0.5) + (0.5)^2 + ... + (0.5)^(n-1) - n(0.5)^n
We can drop the last term because it equals 0 as n approaches infinity
So let 0.5 * S = T = 1 + (0.5) + (0.5)^2 + ... + (0.5)^(n-1)
This is just a geometric series.
So T * 0.5 = (0.5) + (0.5)^2 + ... + (0.5)^(n)
Now all the terms cancel out except for the first and last
So T - T * 0.5 = 0.5 * T = 1 - (0.5)^n.
Again we can drop the last term and solve for T.
T = 2. Thus, from there we find S = 4.
And finally going back, remember the complete sum is S * (0.5)^2 == 1. Yay, isn't math fun?!
blinky8225
564
What class is this anyway? Probability? It looks a little like calculating the expectation of a geometric series.
TecHNooB
7,458
So the series is:
That's so unintuitive and roundabout. I would never make those arbitrary decisions :(
O well, thanks :)
Class~ Probabilistic Methods in ECE
Fenixgoon
33,691
13,420
here's my math problem:
show that (A x B) dot (B x C) x (C x A) = (A dot (B x C))^2
x = cross product
dot = dot product
using indicial notation, permutation tensor, Kronecker delta, and probably the delta-epsilon identity somewhere
blinky8225
564
So the series is:
O well, thanks :)
Well, just do it with variables by letting a1 = (0.5)^2 and r = (0.5). Then, you find a fairly simple formula, you can memorize and never do this again.
TecHNooB
7,458
So the series is:
O well, thanks :)
Which formula are you referring to? I enjoyed seeing the full solution btw :)
MrPickins
792
So the series is:
Reminds me of some stuff we did in Discrete Math.
blinky8225
564
So the series is:
O well, thanks :)
Well for any sequence, where you have a1[1+ 2r + 3r^2 + 4r^3+...+(infinity)r^(infinity)], you will find that the it sums to a1 / (1-r)^2 if you solve in terms of variables. Only ff 0<r<1 of course.
a1 is the first term of the series. In this case it was (1/2)^2. r is the ratio which you multiply each term by, which in this case was (1/2). You don't have to actually factor out a1 like I did. For me, I just find it easier on the eyes.
Furthermore since you're taking probability, let r = q. a1 = pq. p^2 = (1 - r)^2. Then, you just have q/p if you're counting failures of course. It looks a little different if you're counting number of trials. In that case, it's just 1/p, even easier.
