A little html help
Bleep
I want to link my main page to what I am calling page2 I put this in my html for the main page <a href="#another"></a>page2|</A>
and all it does is put page2 at the bottom of the page would someone straighten me out on this??
Bleep
Bleep
Tried that, I now have </A><a href="#another">|page2|
Still dont work, maybe I dont have page2 in the right place. i just have it in the same folder as the main page
Bleep
minendo
35,560
22
<< </A><a href="#another">|page2| >>
Should be: <a href="#another">|page2|</A>
Bleep
Thanks for sticking with me on this, <a href="#another">|page2|</A> that dont work either. here is the target that properties show
file:///C:/WINDOWS/Desktop/PRSC%20site/~temp00.html#another
Bleep
minendo
35,560
22
<< Thanks for sticking with me on this, <a href="#another">|page2|</A> that dont work either. here is the target that properties show
Bleep
What is the name of the page you are actually trying to open?
stndn
1,886
use this: <A HREF="page2.html">page 2</A>
that should link page 2 to open a new page for you (page2.html)
what you are doing is putting a link to the same page (forgot the "term")
basically, what this means:
<A HREF="#myTarget">jump to another place</A>
means that you are looking for this tag:
<A NAME="myTarget">
in your index.html page
with the # sign, the link inside <A HREF> becomes "internal link", which means that the link will take you to where "myTarget" is specified in that page. if you don't have an anchor with name "myTarget", it will just jump to somewhere on the page and you got the URL as "index.html#myTarget"
i have left out some details, but that should get you moving ... if you need more info, drop me a pm or sth
good luck :)
-979-
