I haven't built a rig in almost 4 years, so I'm extremely out of touch with what hardware is good anymore. I'm looking to build a system that'll last 1-2 years and will handle everything I throw at it. My main problem is finding a good OCing MB.
Here's what I'm looking at so far and my reasoning.
CPU: Q6600 (doesn't seem much more expensive than duals and should add some longevity to the system)
RAM: These or the G-skill pair
HSF: Vendetta 2 or Xigmatek with a bolt thru kit (not using those darn push pins)
MB: Here's where I'm stuck. I've done a little looking and was leaning to the Asus P5K Deluxe, then I saw that Intel chipsets don't support SLI, which isn't any good for me. So I need some help finding something between $100-$150 that'll get my Q6600 above 3Ghz.
Case: Not sure here too, need to make sure I can fit the HSF in since those things are huge, just looking for something reasonable
GPU: Thinking 2x8800GT or waiting till next month when Nvidia releases their new parts.
Any advice at all would be appreciated, like I said, I'm pretty far out of the loop these days. I'm upgrading from a Athlon 64 3000+, 6800 Ultra system, so I'm expecting a pretty massive performance boost. Will be nice to finally be able to crank some video settings.
Also, I wasn't sure if this was the right forum or not. I put it here since most of my questions revolve around OCable parts and I remember the other forums used to move incredibly slow.
