jdogg707
Well, it seems that the rear fan on my P180 is dying, the whirring sound coming from it is giving me a headache to say the least. I wanted to replace it with one of these. The fan that is in there now is 25mm, and the Panaflo is 38mm, should I have a problem using this in my case? Is there a better suggestion out there?
Secondly, I was thinking about replacing my Scythe Shogun with a Scythe Ninja in order to get a little bit lower CPU temps while having quieter fans. Would this fan fit onto the Ninja?
Last, but not least, the Panaflo's come with bare wire leads. What connector should I use and is there any special method of installation I should observe? It says not to plug it into the dan header on the motherboard because it could short it out, would this really be a problem on my A8N-SLI Premium? If I could plug both of these fans into the motherboard it would help cable managment tremedously.
Thanks for your help!
