A little help with Firefox
marcello
Ok, I realize I'm just getting on the trolley, but I could use some help. How do I make firefox always open new links in tabs instead of a whole new window. I can't seem to get it to work from any of the options. To me, that seems like one of the nicer features. Thanks
1. type about:config in the address bar.
2. type tab in the filter
3. change browser.tabs.showSingleWindowModePrefs to true.
4. go to tools-options-advanced. or edit-preferences-advanced on linux
5. Tweak tabbed browsing to your liking. There is a force tabs option.
i have another question regard tabs
how do you get firefox to re-open all the currently loaded tabs+webpages upon restart?
i am migrating from maxthon, and i found that feature to be one of the best of that browser. i wonder if firefox allows this feature.
It sure does. Here you go.
most excellent addon. the lite version doesnt work though, the full one works perfectly! thank you much!
another question regarding extensions. i found 2 stock tickers for firefox 1.0, but both of them are for the NYSE, are there any stock tickers available for local markets (viz the Indian BSE)
whatever happened to www.extensionmirror.nl?!?!?!
i am trying to get the session saver again and the page gives a 404 error.
