A little help with fans in a Lian-Li A10 case please?
Dec 1, 2006
51
Please offer help and advice to me on the subject of connecting up fans in a PC case.
(I have created this post in word and pasted it into the forum because it?s a bit long and it took me ages to put it all together)
This issue plagues me whenever I build a new PC or upgrade my old ones. I have never quite got it right. If I am unhappy about case fans then I am sure loads of other casual PC builders are as well, so this post might be of help to more people than just me. In any case the process of just writing this post has helped me.
This post is only about air cooling.
1)SOURCES OF POWER FOR FANS:
1.1) My Motherboard (MSI P965 Platinum):
The Motherboard BIOS is v1.1 (I know v1.2 is available, will load it later):
There are four fan power plugs on the motherboard. I use the word ?plug? deliberately. Each plug is a plastic mounting with pins sticking out of the motherboard. They are:
1.1.1) CPUFAN1 (4 Pins) Pins: GND, +12V, Sensor, Control
1.1.1.1) Monitored in BIOS (RPM). I assume this uses the Sensor pin. (Correct?)
1.1.1.2) In the BIOS it is possible to set ?CPU Smart Fan Target? between 40 Degrees C and 65 Degrees C . I assume this refers to CPUFAN1. (Correct?) This must refer to the CPU socket temperature and not the CPU internal temperature (Correct?)
1.1.1.3) What is Control?
1.1.2) NBFAN1 (3 Pins) Pins: GND, +12V, Sensor
1.1.2.1) Monitored in BIOS (RPM) I assume this uses the Sensor pin. (Correct?)
1.1.2.2) Took me a long time to figure out what this was. Then found a forum post referring to ?NorthBridge Fan? so NBFAN1 is the NorthBridge cooling fan. The only thing is that my motherboard has passive cooling on the NorthBridge. I assume I can plug in any other fan if I want to. (Correct?)
1.1.3) SYSFAN1 (3 Pins) Pins: GND, +12V, Sensor
1.1.3.1) Monitored in BIOS (RPM) I assume this uses the Sensor pin. (Correct?)
1.1.3.2) In the BIOS it is possible to set ?System Smart FAN Target? between 20 Degrees C and 45 Degrees C. I assume this refers to SYSFAN1. (Correct) The sensor must be on the motherboard somewhere. (Where?). Default is off.
1.1.4) PWRFAN1 (4 Pins) Pins: GND, NC, +12v, Control
1.1.4.1) What is this for? The power supply doesn?t have anything to plug into this?
1.1.4.2) What is NC and Control
1.1.5) Questions about the four plugs above:
1.1.5.1) What is ?Control??
1.1.5.2) What is ?NC? (No Connection possibly)?
1.1.5.3) The motherboard manual says that fans have a red wire which is + (Is it always red on all fans?) and a black wire which is GrouND (Once again always?)
1.1.5.4) In the BIOS it is possible to see the speed at which fans are spinning (RPM) for CPUFAN1, NBFAN1, and SYSFAN1. Looking at the little table above that must be what the ?Sensor? pin is for. (Correct?) Do all fans with three wires have speed sensors. If not what else might the third wire be used for ?
1.1.5.5) What does the BIOS actually do to the relevant fan when the temperature is below, at and above the SmartFanTargets? Is it a trigger temperature at which something starts to happen (like a fire alarm going off) or is it a target temperature the BIOS attempts to maintain (like a central heating thermostat). In both cases I?m assuming the only action the BIOS takes is to vary the relevant fan speed? Having thought about it a little while writing this I think the latter case must be true.
1.1.5.6) The four plugs I am discussing are obviously intended to take one fan each. Is it a bad idea to use some kind of Y cable to drive more than one fan from each?
1.1.5.7) Can each plug take any fan of any size. I am not much into electronics but I would guess that bigger fans draw more current. A little NorthBridge fan must be different from a big 6? case fan.
1.1.5.8) Should I just leave a plug on the motherboard empty if I am not using a fan for the intended purpose?
1.1.5.9) Is there any problem using an extension cable with a fan assuming it is intended for the purpose, ?straight-through? and the number of pins is the same.
1.2) Power cable from PSU with appropriate converter on end.
1.2.1) For Instance: Cable from PSU terminated by standard molex connector WITH molex to 3 pin adapter.
1.2.2) Specific Questions:
1.2.2.1) How many fans can run off one molex ?
1.2.2.2) Is there any problem ending up with quite a complex web of cables off one Molex, for instance daisy-chained ?Y? connectors, lead extensions etc.
1.2.2.3) The cable from the PSU would have two molex connectors on it. Is it wise or problematic to run fans etc off one and peripheral devices like HDD off the other?
1.2.2.4) Presumably running a fan in this way means that only a simple fan can be used. It can only run all time at 12v with no monitoring or speed control etc.
1.3) Fan Controller Unit
Writing this little epic I have pretty much convinced myself that fan controller units are a good idea. I have owned an Akasa unit for several years and its been mounted unused in one of my PCs. I could just never face the hassle of setting it up.
1.3.1) Questions about fan controller units:
1.3.1.1) General advice, things to do, things not to do?
1.3.1.2) Any power problems with large numbers of large case fans?
1.3.1.3) I am nervous about putting my CPU cooler fan into one of these. If I had one I would also worry about the NorthBridge fan. What is the general consensus of opinion ? leave it in the motherboard or plug it into the control unit. I see scope for expensive disaster here! The motherboard would have fan failure detection.
1.3.1.4) All those nasty little sensors ? where best to put them, how to safely attach them?
1.3.1.5) I assume fan controller units are driven by a molex connector, but if driven by a little 3 or 4 pin fan-type connector ? is that really OK?. Those wires are awfully thin?
1.3.1.6) Are they reliable?
2) FANS
2.1) Questions:
2.1.1) When buying a fan for a particular job in a PC system ? please provide a checklist of things to consider and get right. What are common mistakes? 2pin? 3pin? 4pin? Male connectors? Female connectors? Different types of fan?
2.1.2) When putting a fan into a system what are things to consider and what are common mistakes? I can think of one ? wrong polarity would cause blowing instead of sucking and vice versa.
2.1.3) Are fans ever two pin?
2.1.4) How long should a fan last. When a fan starts to grind/fail/stick/seize does it potentially have the ability to damage anything by drawing too much current?
2.1.5) Is fan speed controlled by reducing voltage only?. I have seen little link wires advertised which drop the fan voltage by a couple of volts I assume to quieten the fan. What do people think of these? I wouldn?t use one on the CPUFAN in any case.
3) MY LIAN-LI A10 CASE FANS
If the questions in the sections above are answered I will be well on the way to having the information I need to work out for myself how to permanently wire up the Top Case Fan, the Rear Case Fan, the Duct Fan in the duct over the expansion slots, the CPU Fan, and the fan in the front driven by Lian-Li?s special 3 way speed control switch.
3.1) Current temporary configuration questions:
CPU Cooler Fan: Connected to CPUFAN1 and working fine
TOP Case Fan (Practically touching CPU Cooler): NBFAN1 ? no real reasoning
Rear Case Fan (Near CPU Cooler): SYSFAN1 ? seemed sensible
Ducted Fan (Over expansion cards) ? The machine still has half its guts hanging out all over the table, but when the build is complete and the ducted fan is replaced it will need power from somewhere not in yet
Front Case Fan ? with Lian-Li 3 way switch ? not connected yet
Outside of this discussion:
Video card cooling fan ducting air out of case to expansion slot at back of PC ? OK
PSU contains two fans one large and one small ? seems to be working OK.
3.1.1) The CPU fan is a no brainer and is fine. The wires from the fan on the front with the three way switch are terminated by a plug with three pins inside which needs a socket to receive the three pins. The top, rear and duct fans all have wires terminated by sockets which will receive a three pin plug. Why are they different? Currently I have nowhere to plug the front fan in without buying an adapter. Do any practical experienced people out there have suggestions for a wiring scheme for all these fans?
4) Thank you for reading this far.
4.1) End.
ShockwaveVT
830
edit - longer response coming. Although I can't stand the way you laid out your post & questions I'll help you out since I have personal knowledge of the PC-A10.
3NF
1,345
I replaced all of the fans that came with my Lian-Li PC-A10B case with Skythe fans from newegg. All of the fans connect directly to the motherboard and I modified the duty cycle for each one in the BIOS, so that it runs a bit slower than it's top rated speed.
I tried reading your entire post, but quickly encountered a BSOD in my brain :)
ShockwaveVT
830
These plugs are more properly referred to as headers.
1.1.1.2) In the BIOS it is possible to set ?CPU Smart Fan Target? between 40 Degrees C and 65 Degrees C. I assume this refers to CPUFAN1. (Correct?) This must refer to the CPU socket temperature and not the CPU internal temperature (Correct?)
Correct and Not Sure (it doesn?t really matter though ? I personally don?t even bother with these kinds of settings)
signal for controlling fan speed?
correct
my opinion is that any other 12v fan would be fine
Correct..
Its probably near the North Bridge chipset. If you really care to know, call MSI.
This is not for the power supply? its just another fan header for you to plug a case fan into. I?ve almost always left it unused.
controls the voltage used by the fan ? controlling the rate at which the fan spins
no idea? very likely not important
pretty much
the 3rd wire is almost always for speed sensing.
Since I don?t have your motherboard, I can?t answer that question. I suggest calling MSI if you actually care.
Yes, it?s a bad idea
A 12v fan is a 12v fan. A 120mm fan would be fine plugged into that.
It wouldn?t hurt to do that.
no problems
As many as you want.
Nope, aside from being messy.
Not a problem.
Pretty much. But why do you care so much about how fast your fans are spinning? And if you want speed control get an add-on Fan Controller. Usually they are devices that fit in a drive bay and have 4-5 knobs to control the voltage provided to different fans.
Fan controllers are nice if your case fans are too loud and you?re going for a near-silent computer.
don?t attach more than a couple fans per ?channel? on the fan controller
Define large numbers? 4-6 120mm fans is perfectly fine.
Just plug it into the CPU Fan header on the motherboard unless you?re overly concerned about creating a near-silent PC.
I don?t really know what you?re referring to. Temperature Sensors? Place them wherever you want to.
Simple solution, plug your Fan Controller?s main power into a molex connector?
Are any solid state electronics reliable? It all comes down to the manufacturer?
2) FANS
2.1) Questions:
1. Size. Make sure they fit the fan mounts in your case. Common sizes are 80mm, 92mm and 120mm. Your PC-A10 uses 120mm exclusively. Most fans come with a molex connector and a 3 pin connector. (sometimes there?s no 3rd wire but it?s a 3pin connector).
If you plug the fan in properly there will be no ?polarity? issues. Its just a matter of making sure you install the fan facing in the proper direction?
Yes, but they have 3-pin plugs. The RPM-sensor wire is just not included
Years, and its extremely unlikely that a dead fan would cause any power problems.
Pretty much voltage regulation is the way fan speed is controlled. Personally I prefer to purchase fans that run quietly at 12v rather than bother hooking up fan controllers and dialing loud fans to a slower speed in order to quiet them.
OK, I have a PC-A10 and here?s how I have the various fans hooked up.
CPU Heat Sink Fan is connected to CPUFAN header on the motherboard
Front 120mm Fan (intake) is connected to the case?s built-in fan controller (channel 1 of 2)
Top 120mm Fan (intake) is connected to the case?s built-in fan controller (channel 2 of 2)
Rear 120mm Fan (exhaust) is connected to a 3-pin to Molex adapter and connected directly to the PSU. (For neatness, the wiring is tucked along the top edge of the motherboard then goes behind the optical drive slots where it plugs into the Molex)
Slot Cooler 120mm Fan (exhaust) is connected to a 3-pin fan header on the motherboard due to proximity when installed.
(I kept the stock fans because the ones that came with the Lian Li aren't that loud)
As far as where you "should" plug in your case fans... I recommend keeping it simple and keeping your wiring neat inside your case so the airflow from the fans isn?t restricted by tangles of wires and cables.
4.1) End.
Next time try and distill your questions before posting them. Keep your post short and to the point, and if you have 30 questions, break them up and ask them 2 or 3 at a time.
Honestly, you're lucky that anyone bothered reading such a long and convoluted post, much less reply to it with useful information..
Dec 1, 2006
51
Many thanks ShockwaveVT, 3NF.
3NF, I hope your brain rebooted safely :)
Yeah, OK ShockwaveVT, point taken. It was a bit long. I got carried away. Sorry. :eek:
Thank you for taking the time to answer all those irritating little questions that have bugged me for ages. You are so right about tidying up the cables - once the new build has been running OK for a few weeks all that spaghetti needs to be sorted out.
One short supplemental if I may...
The top fan (Very close to CPU) blows if plugged into the motherboard and sucks if plugged into the front panel. Did you choose the option you ended up with deliberately and for specific reasons(positive/negative pressure, max out CPU cooling, subtle airflow arguments, etc) or "just did it that way".
Thanks again
ShockwaveVT
830
mine came with the top fan mounted as an intake.. not sure why it would change direction depending on where it was plugged in... case fans are designed to push air in one direction (typically in the direction of the 'closed' side of the fan - the side with the center mount and support bars.
