A little help with ASRock x99 Extreme 4 problem
jim1976
2,704
Hi guys,
yesterday I added a second 980Ti on my mobo for 2 way SLi. I am using the x99 extreme4 as I said in the title and a 5820k.
My problem is that when I place the second gpu in pciex16 slot 3, this covers the only pci slot which is directly below it and I cannot use my ZxR card.
Now if I place the second gpu in pciex16 slot 5 down below I don't think it will work with 2 way SLi, or am I mistaken?
It's a huge problem since onboard audio cannot compare with my ZxR. Am I missing something obvious here in the mobo layout or is there any other alternative?
Thanks in advance for any help
LTC8K6
28,520
1,575
I don't think there is an old PCI slot on that board?
PCI-E 1 and 3 only for 2 way SLI.
Put the sound card in slot 5? A 1X card should work in any slot.
jim1976
2,704
@i7baby
Not working m8, just tried it with the long bridge connector and cannot enable sli..
@LTC8K6
I'll try to put it in slot 5 and check. Thanks for the help
jim1976
2,704
edit *It WORKS now SLi is enabled and ZxR is working on PCIe slot 5 but I get less performance from my SLi system, though in GPUz it's still recognized as x8 for both GPUs
jim1976
2,704
Edit.
It WORKS now SLi is enabled and ZxR is working on PCIe slot 5 but I get less performance from my SLi system, though in GPUz it's still recognized as x8 for both GPUs.
Any idea on how to deal with that?
jim1976
2,704
Nm the hinder of performance was my fault with a messed up o/c profile in Afterburner after I swapped cards and re-enabled SLi.
Everything seems to be working fine now thanks everyone for your help.
