MatrixAgent
Ok so I'm having a few problems with my system and keeping it stable.
The relevant specs are Asus striker extreme(latest Bios), C2d E6420, 4GB Corsair TwinX XMS2 4-4-4-12 DDR2 800 at 2.1v.
Cooling is a Thermalright ultra120 with a scyth 1600RPM fan attached. I've also added the extra North bridge fan which Asus supply with the mobo.
From what I've read(Yes I've google'd and used the forums search function - so please don't grill me!) the 6420 lends its self to oc quite nicely as does the striker board but.... At 3.2ghz it just freezes whilst running Orthos(blended), The temp(measured using core temp) seems to never rise beyond 54c under load 27-29c idle which is well inside the safety margin. Currently I've got the Vcore at 1.35v and FSB 400(alowing 1:1 ratio which
I've read is a wise thing), the DDR2 is set at 2.1v(as per warranty)
Any ideas? last run lasted about 1 hour 15 and then froze(total system freeze - hold power for 5 seconds etc to power off) - that was with a 1.368v vcore.
so I've dropped the vcore to see if that helps. I've not touched the north/south bridge voltages as I've not found any conclusive info on what is a reasonable for this board/these speeds.
Any advice on what to try next would be appreciated.
Regards,
R.
Regards,
R.
