Client has amd k2 350 system...On bootup, fails to detect the hard drives...master and slave on ide1...Went over there last Monday, pressed the cable connections and got it back up. Gave it a thorough scandisk and defrag. Replaced the cable with a used spare.
System was booting ok until this afternoon. He left the computer on the desktop and a couple of 10 minutes later returned to find a hd err msg (which he didn't write down). Tried to reboot...no harddrives detected.
I think that because it posts and will run thru the ide detect that this should not be a bios issue since it will boot from a startup disk..but would like confirmation. If it were a harddrive issue, I would expect that the slave would be detected and it isn't. Sounds to me like the mb is history.
Has anyone seen anthing like this before? Is there any other testing I could do to rule out the mb? TIA, Paul
