A LITTLE HELP HERE
GOG427
14
HI ALL HOW IS EVERY ONE?
WELL HERE IS MY ? I GOT1.4 266 T-BIRD ,256 PC2100 DDR I NEED TO PICK A MOTHER BOARD ANY IDEAS WHAT IS BEST ONE I DONT REALLY WANT OVER CLOCK I JUST WANT A GREAT BOARD HELP PLZ:D
Buz2b
4,619
First thing you need to do is turn off your caps lock! That is considered "yelling" on the net.:frown:
Next, try to do a little searching before you ask a question. All you have to do is scroll down about 14 or 15 threads and you will see one originated by AGodspeed. In the title it has the word "Motherboards" and the phrase "Which is right for you?" Seems like that is where you need to go to get some answers. Good luck!
Rafael
868
Epox 8KHA or 8K7A, Asus A7M266 or A7V266, or even the Abit KG7.
All DDR mobos, and very good mobos!
Good luck!
Raf
GOG427
14
Well iam sorry about the CAPS i was very drunk at the time and i did look at all the reviews i want a good POV... so thx
cybercry
12
If you have the time to wait look for the new Nvidia chipp set boards coming out.
o1die
4,785
ECS K7S5A is only $66 on pricewatch. Early reviews are good. With the money you save, buy a decent video card, which will improve performance more than an expensive motherboard.
