- Aug 31, 2001
- 21,205
- 165
- 106
This is my basement finishing plan
Seating area will most likely be around or a little forward of where the stairs end. So seating will be 12-16' from 15' wide wall. Since Im finishing this basement from scratch, I have complete control of lighting, and project placement. Projector will have to be ceiling mounted. Ceiling height will be 7' when the basement is finished.
The projector Im considering is either the Panasonic PT-AE4000U or the Epson 8100. I was reading thru this review on projectorcentral and it says
I was playing around with the projection calculator for the PT4000U. I know I want a 100" screen on the 15' wall (next to the 3'7" door). Leaving the screen slider at 100", if i slide the zoom slider all the way down to 1.00X, the throw distance goes up to 19', and I get image brightness of 16fL. If I move the zoom slider up to 2.00X, throw distance goes down to 10', and image brightness goes up to 27fL. The complete opposite to how I understand this to work. Well I get that the closer the proj is to the screen, the brighter the image, but why does moving the zoom slider up bring the proj closer to the wall?
So confused. How far should I place the projector from the 15' wall for best brightness and image quality?
The following are my understanding. Correct me if Im wrong. Im assuming Im supposed to leave the projector's lens at the lowest zoom setting (widest angle) to get the highest lumen output. Having it at the widest angle will mean that the projector will have to be placed closer to the screen.you lose up to 41% of potential light output if you set the 2.0x zoom lens to the maximum long throw position (smallest image from any given distance).
