A lil memory timing help?
cerebrix
HI there, there are a few settings that im unsure of what I should set them to in my bios for my system. Mind taking a looksie and giving me some advice? Ill post what settings i have now and ???? for the stuff i currently have set at the defaults ok?
Motherboard: Gigabyte GA-K8NXP-SLI
Ram: KHX3200AK2/1G (datasheet available in pdf format at http://www.valueram.com/datasheets/KHX3200AK2_1G.pdf)
heres what ive got so far:
cas latency 2.0
row cycle time (trc) 8
row refresh cyc time (tRFC) ????
ras to cas delay (tRCD) 3
row to row declay (tRRD) 2
min ras active time (tRAS) 6
row precharge time (trp) 2
write recovery time (tWR) 3
write to read delay (tWTR) 1
read to write delay (tRWT) ????
refresh period (tREF) ????
read preamble value ????
async latency value ????
CMD rate 1T
Thanks for taking the time to read my questions and thanks in advance for tryin to help me out
-Me
an easy thing to do is to d/l a64 tweaker, set your multi at what you want to run at and all your timings to "auto". then boot and run a64 tweaker and write down whatever it determines your ram has benn set to.
