a li'l help with celeron 300a O/C??
technoman28
Hi all. firstime here, but love this site so far. Yeah, i know it's late to start tryin to overclock my malay 300a celeron, but since i wanna upgrade past 1 Gig soon, i figure it's o.k in case i fry anything.
I've just upgraded to the latest bios on my abit BH6 rev.1 MB and tried to boot my system at 100MHZ x 4 and 4.5 - pci bus at 2/3 with no success. At 2.3v, my system finally boots past the windows 98 r.2 screen, but then gives me an message saying there is a windows protection violation error & to restart. Step by step confirmation hangs after loading himem.sys driver. Anyone experience anything similar? I really wish now i had done this when this was the hot o/c item at the time so there might b more info still around.
Could the prob be crappy memory? I have 64 MB of generic 100 mhz sd and i tried adjusting cas latency between 2 & 3 with no effect. Oh yeah, i did thermal grease my chip with dual fan heatsink. Don't know what else to try, any suggestions would b great!! thanks, T.M
Nick Stone
1,033
You want the AGP/FSB set at 2/3 and the PCI/FSB ratio set at 1/3 in case you don't have it set that way already. Can you increase the cooling by leaving your case cover off and pointing a fan toward the inside of the case?
technoman28
OOPS!! My Bad. I meant i set the agp bus to 2/3, not pci. actually, i'm not sure what i set the pci bus to. I downloaded the bh6 manual here at work and it seems the fraction after the 100 mhz setting is the pci bus speed?? Might have been at 2/3 -if that option is even available. Can't wait to get home and find out. Would b great if that was my mistake and things then worked, but thanks 4 the tip Nick!!
ps- i will leave the case off etc, but i thought that sort of overheating would only affect stability after the cpu's been running awhile. I'm struggling just to get win-doze to boot! :D
pizon
64
Make sure speed error hold is set to disabled in the bios when overclocking. good luck.
Bartman
Welcome to Anandtech.. may I be the first to invite you to join Team Anandtech's OGR team? I'm sorry that I can't explain more but if you swing by the distributed computing forum they would me MORE than happy to help you out, just ask.
Bart
Chuffmaster2k
452
Did you up the voltage at all? The processor probably needs more voltage to get a higher speed. I do not remember the default voltages. Good Luck.
they call mr big
417
the PCI divider should be set at 1/3 at 100 mhz bus. what case cooling do you have??? I had the same problem with my 566 until I got gorb and couple of 120 mm fans in the case, now at 850 mhz stable. good luck
