A-i-w 9800 Pro Video Capture Problem. Hlp Pls
leousb
Just recently bought an ATI All-in-Wonder 9800pro card and have yet to get it to capture . (btw I'm presently running winXP SP2).I have the card installed and I have my ati inputbox (that purple box) hooked up to the card and a single RCA,video cable going into the video-in slot of the box (the other end goes to my VHS ).
I've been trying to use the included ATI player (MMC) to capture video but to no avail, tried Pinnacle Studio 8 and nothing..
When I play the tape I get nothing on the PC screen,
Tried rebooting - nothing
Tried checking the wires (of course) and they look ok.
Double check in software (MMC by ATI) that the input was "composite" the other options are tv, and S-Video, nothing
Any help would be GREATLY APPRECIATED . I basically bought this card to back up my VHS collection so pretty frustrated here .
Looked for the ati guides and they´re horrible for this troublshooting
Thanks for any and all help 🙁
You have the yellow connector connected? (You'll also need the audio connectors if you want to capture the audio)
Does your VCR have an option to pick the ouput connector? If you disconnect the cable from the purple breakout box and connect it directly to your TV...does it work?
