A good heatsink to use in a microfly (need to use for overclocking)
SwiftWind
I'm currently using an XP-120 to overclock an Opteron 148 to a 2.86Ghz. I doubt the xp-120
will fit in the microfly, anyone know?
If not, can you recommend any heatsinks that'll fit that will give the same performance?
Thanks!
The 7000B-Cu fits fine. I'm looking at mine, and I think that even the 7700 would fit (providing it'll clear my RAM).
But the 7000 fits in there, no problem.
PM
The Micro Fli isn't exactly as much of a "micro" as most. I'm using one for a (not yet built) basic web surfing and utility usage system where space is slightly tight for any sort of tower, even a micro there, and I didn't like the horizontal "desktop" options in the small size. It's about the size of the Aspire X-Qpack, with the same handle on the front. I do like the ATX size PSU space allocation.
