A few small nicks on heatsink... will it really affect performance?
Tachion
I'm switching back to my stock P4 heatsink since the one I have now is extremely loud and almost unbearable.
It's the standard P4 one with a copper core right over the die and aluminum fins surrounding is. The few small nicks and scratches are on the copper part, unfortunately.
If I put some arctic silver on, is it still gonna lose a ton of cooling efficiency?
http://img402.imageshack.us/img402/4785/dsc00121wp8.jpg
Thanks.
f4phantom2500
2,284
imo that doesn't look too bad, the only way to find out tho is to use it; i doubt it's bad enough to let your processor overheat, so if i were you i'd just try it and keep an eye on the temp, see if it gets too hot.
trOver
1,417
you can shine it back up by sanding it with some very high-grit sand paper (1000 or so)
aigomorla
21,086
3,593
i would suggest a XP-90 with a quiet 90mm fan.
The stock is also LOUD if i remember correctly.
What is your current HSF?
Tachion
My current HSF is some cheap CompUSA (yeah, I know) thing. It's copper but the fan vibrates a lot and is loud. It keeps it cool (about 36 idle w/ crap silicone grease) but is just too loud.
I had a Zalman HSF before that in my old case. I couldn't use it in my new case though since the fan mounted on the PCI/AGP card slots (, and my new case is screwless, which is why I went with a cheap CompUSA one. This is what I had in my old case.
I was looking at another Zalman (this one), but I don't think it will fit since I moved to a mid-ATX from a full ATX.
Basically, if my stock HSF will just not vibrate, that's all I care about. I can stand the drone of a fan, but not the "pulse" of a vibration.
Maybe I should just dig deep in my screw jar and try and force the Zalman fan on, though. That thing was really quiet.
Tachion
I managed to fit my old Zalman into this case. The screwless clips popped off easily and I had some screws that fit. Much quieter and it's already running around 36-37 idle w/ Arctic Silver, which is what the other HSF did after 3 weeks of burn-in.
Anyways, thanks for the help.
aigomorla
21,086
3,593
Best HSF for price and performance
Here op, i suggest you get this and replace your old one with it.
They perform pretty darn well, and there quiet. Not to mention 16.50 cents is a hard to beat deal.
