A Few Questions/Problems
TheGeek
1,090
So I have been having problems with my network recently and I was wondering if anyone could help me. I have a Netgear WGT624v3 router logging into my Bellsouth DSL connection through a Westell E90-610030-06 modem. The problem is that occasionally, usually when I am downloading large files, my internet connection will all of a sudden cut out. My computer will tell me that it cant connect to the network because it cant receive a signal from the access point. The only remedy is to reset the router. Anyone know why this is happening or how I can fix it? I don't know if this is correct at all, but I have a feeling that it may be because I am logging into my DSL connection through the router rather than through the modem. When I use the modem to login, I can access the internet fine on my computer. But once I plug the router into the modem, all of a sudden the modem can't seem to connect. Can anyone help at all? Thanks. This is extremely aggravating because I cant leave my computer donwloading overnight because it will just disconnect after 10 minutes and I cant do anything about it while I'm asleep.
TheGeek
1,090
I cant keep my computer wired in, but I just tested it and I didn't have the problem though, but I don't know if I didn't leave it plugged in long enough. The problem is that my connection comes in through the living room, and me and my roomies all connect wirelessly, and i'd prefer to keep my computer in my room.
JackMDS
29,544
421
Then get a New Router that can transmit better and put on it a better Antenna.
