- Feb 14, 2005
- 10,320
- 672
- 126
Originally posted by: error8
Originally posted by: chizow
Originally posted by: munky
Originally posted by: tigersty1e
Of course you could also overclock the GTX and have card that's better than the OC'd GTS.
I don't get why people mention overclocking a lower card to get the same performance of the current card when you would also be overclocking the current card to get better performance.
The only exception to this is possibly the 2900pro ---> 2900XT.
There's no guarantee that the gtx will OC higher than the gts. Clock for clock these cards will have identical performance.
The memory should for sure. Contrary to reports that this card is identical to the G92 GTS, the GTX does have the 12 layer vs 8 layer PCB, 5 phase power compared to 4 phase (not sure on the exact #, but GTX has more), extra 6-pin connector, higher stock voltages in BIOS, faster memory modules (8ns Samsung, same as the Ultra). The core itself also has a different designation #, G92-450 I believe compared to G92-400 on the GTS. It might be nothing more than binned cores or even a later production run but usually that's all you need with CMOS chips to gain an edge in clock speed. Typically these factors contribute to a faster part as a whole when you look at other parts (like motherboards, memory, cpu, gpu etc).
Yes, and also the GTX has 24 ROPs opposed to 8800 GTS 16 ROPs.
you sure?
richuk: crank up the core on that card! hopefully it came with the higher Gpu Vcore like the 8800 series BFG cards did.
Originally posted by: RichUK
Having never used this ATI Tool before, when scanning for artifacts are you supposed to only see a static image with a timer at the bottom left?
If I click on ?show 3D view?, I do get a moving object with an FPS indicator, however.
I take it this is normal? if so, which is best for testing your OC?
Thanks.
Thanks.
I do it like this. I let the cube spin for 10 minutes at least, so that the card reaches the maximum temperature. After that I press "Scan for artifacts" and let it run for 10 minutes. If it is stable I increase the clocks further and rerun the test and so on until I run into trouble. When I do get artifacts, I'll lower the clocks with 20 mhz or so and then run a "mega" scan for an hour. If it passes one hour I think it is already some 90 % stable.
Another thing is to increase the clocks independently. Overclock the GPU first, then the shaders and then the memory. When they've all passed the one hour test you can throw games in the card and see if it does give you problems. If it doesn't then it should be perfectly stable.
Thanks.
Ahh, cheers.
Was just having a quick play and ramped up the core clock (linked with shader clock) to 830Mhz. I then ran the ?scanning for artifacts? test. It seemed ok for a while, but then I started to see random yellow specks popping up, so I set it back to default (675Mhz, I believe).
I think I?ll have a quick go on crisis, and then have another attempt at OCing the card later on.
Doesn't bother me, it's just pocket change.
damn! 830mhz core, "just messin' around"
that's pretty nice. i bet we get to see 1ghz on this core in the next few g92 products
Thanks.
A friend wanted a cheap PCI-e card for his comp, so I thought I?d off load my 7900GTX on to him for £70 and just upgrade to the 9800gtx.
I was originally going to buy an 8800gt, but then I released the 9800gtx had been released and was up for sale, coincidently on the same day I went to purchase the 8800gt.
If it is pocket change, why don't you just buy three of them and put 'em in triple SLI????
Because there?s no requirement, I?m running a 19inch 1280x1024 monitor.
Thanks.
Make sure Fraps isn't on! I've killed a card like that :roll:
Just get this then: http://www.newegg.com/Product/...x?Item=N82E16824001266
Then you'll have the need for Multi-cards
Originally posted by: lopri
Hey Rich, it's good to see you. Grats on your new card. Your old card looks familiar to me for some reason. How's things?
Originally posted by: JACKDRUID
nice graphics on the new card. gratz
is it venting out of the back of the case?
